brakes
still having a prob with my brakes sometimes the pedal travels half way other times its normal other times its really solid goes soft when car has been stood or traveling for a while stiffens as u use it not loosing
any fluid from calipers or master cylinder in fact there really diff to bleed if u press the pedal and open the bleed nipple you get 1 loy of fluid then second time nothing at all and fluid in master cylinder stays the same if u close the bleed nipple an leave it to gravity all goes back to normal really puzzled
