question for the sparkies
okay , my TT rear subframe and hicas was swapped out for an NA one,
The hydraulics removed in the engine bay, just the grey connector left now as can be seen from the picky.
I noticed my hicas light was perm on,
Pc two shows the main ECU on top and the Hicas ECU beneath.
I was advised to remove the connector to the right to resolve the hicas light , this worked , however my Cruise no longer functions,
so , Is there just one wire I should cut on the second plug to turn the hicas light off but to leave my cc systems working . if so which one,?
Or should I loop the grey connector shown in the engine bay to cheat the system, again if so which wires should I connect to each other
Any thoughts drop me a line using 07929 159828 or message on here
Many thankshttp://s1048.photobucket.com/user/sayersneil/library/?view=recent
Vodkashots showed me this once -
It's the ECU wiring colour codes -
[ATTACH=CONFIG]70012[/ATTACH]
Might help..
Edited by MasterCookieman
Why not just remove the hicas bulb.....simples.
Jeff
because If the fault is there it will be stopping my cruise control from engaging . or is that another issue
