boost controller fitting.
Which pipe is it you need to tap into?
Is it the pipes that the boost jets go into. So T. Them together then into the valve. Back out then into a T then back to the pipes that had the boost jets?
you need to remove the jets ..
the 2 Feed outlets on the hard boost pipes need 2 be T together and then to the Input on the EBC Solenoid and then the 2 turbo lines u need to T together and then back to the EBC Out Put on Solenoid
Cool so it is the ones I've put the boost jets in?. Just using the jets as a reference point :)
Sound so the solenoid is no the same pipes and doing the same job as the jets. Nice and easy 2 min job :)
