rebuilding manual gearbox
what sort of price for maual box rebuil am i looking for and who can do it? i can`t get in to first gear while moving .... i have adjusted clutch pedal to the max and extended slave cylinder rod with no luck
you sure clutch isent fecked?
brand new oem clutch ... second hand fly wheel and second hand clutch pressure plate
I'd suspect the 2nd hand pressure plate before the g/box....I have even seen high spots on flywheels cause this issue, granted on HGV's but it's the same principle.
I'm not sure about price but rebuilding a box I'm guessing would be specialist stuff only. So many parts I wouldn't recommend it at home unless you've a nice long workbench and alot of patience and good memory lol
