Fitting Intercooler Hard Pipes???
Hi all, I need some advice on fitting the TT hard pipes that go out under inner wing to intercoolers...
I am doing N/A to TT conversion and can't get them through the gap, it seems too small to fit them through???
I also can't see any mounting holes or brackets that the pipes mounting points line up with??
Anyone got some pics of these pipes fitted please???
Cheers....
Russ
I am taking it they go in gap between anti roll bar mounting and box section?
Do I need to drop the antiroll bar mounts to feed it through or is there a trick to feeding them through?
You have changed the radiator right?
Have a very nice large alloy rad for a TT...
I have the pipes either side of rad replaced, ones with recirc valves are in, but cannot get the ones that go out under inner wings to go through between antiroll bar mount and body.... there are no apparent mounting points either....?
Bump..... Anyone removed or fitted these ??
they do fit but have to be honest you would think it you have keep wedgeing them through bit at a time they are a pain
I just repainted them and they looked so nice, now they look worse than before I painted them......and I still couldn't get them through the gap.....lol
I will try again later weather permitting.....lol
Thanks for the reassurance....
