jap to uk seatbelt upgrade
Has anyone done any guides for this.
I wanted to move the front seatbelts to the pillar but i can find the lower anchor point? :no:
I have done this. (its not strictly a jap to uk thing...all Japs after 92 had seatbelts on the Pillars).
Lower anchor point should be there, behind carpet. Upper point is the problem, You need to weld in a threaded plate behind it. I used a FIA regulation harness mounting plate that I cut down to fit inside the narrow b-pillar space.
Edited by Yowser
does the top have to be threaded,I thought it was like the door mounts with just a bolt going through a hole and a nut on the other side. didnt have time for a good look though
Its missing the thicker reinforced section that should be there. Just putting a nut behind the thin sheet metal would be risky. The fia harness mounting plates are basically just steel plate with a welded on nut, but it allows the load to be spread better. You just need to cut down the sides enough for it to fit inside the panel. (http://www.ebay.co.uk/itm/Harness-eye-bolt-backing-plate-FIA-approved-/260981211348?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc3b140d4)
I've got my old UK belts if you need any as I you won't be able to use your import ones I don't think.
Or just buy the "weld in" version!
http://www.jjcraceandrally.com/rally/accessories/omp-weld-in-eye-bolt-plate
