car wont start
ok just checked petrol lines all ok checked plugs thay where wet cleaned them then checked for spark on the coil pack all fine pulled all plug off and cleaned them so the job I did with the car manual conversion, polished plenum on, new rocker gasket and sealant, new plenum gasket, that's it car ran ok before so turn the car over fine pump fine wants to start then dies looked at ecu got 5 long and 5 short blinks ted
gasket ok on the ilde control valve seems that u swapped plenum over ?
what about the pipes that go in to plenum for the egr ?
all boost pipes are ok ?
ย
you have connected the fuel lines the right way ..
ย
Fuel Supplie ( Filter ) going to the Left Regulator and Return on the Right Pressure regulator ?
hi mark iv removed the egr all together the petrol filter hose to the left to a little black thing laying flat one part goes down to the engine and the other part goes to the balance bar the 2nd line come from a 2nd black thing think it called a damper that stands up back towards the filter but goes to hard pipes and the small hose goes to the balance bar and the aav got a new gasket on
she started and runs not for long but it runs
