N/a v's tt short engines
Just a quick question. Is there much difference between the short engines in a tt and an n/a? Or is it down to manifolds and ancileries?
nope its the bottom end that's different ( short block )
Block
Oil Channels/outlets blocked off
Different Pistons and Compression ratio
Oil Pump not really a problem
the Main thing that's different is the pistons .. changes the Comp ratio but all so they are not quite as strong
Rods/crank/Bearings are the same
so really u can buy a NA short block .. swap pistons and Uncap the oil ways and turn it in to TT block quit easy
if you know how
Heads
Year 89>91 had softer valves and porting slightly smaller Heads same from 91>99 p48 same on all the engines
NA Cams have different Timing Profile .. very close to the Auto TT cams Pre 94
Other cam differents besides auto/Manual
TT 89>94 Shorter old once piece sprockets ( Inlet )
TT 94>99 Longer by 8mm use 2 piece sprockets ( Inlet )
and im sure there are some of the TT Engines around 98>99
thats fitted with No VVT
Edited by MarkDerby
Thanks mate, good to know the difference as I was told they are the same but I was thinking that big ends at least where different.
if you know how :)
