gearbox
hi guys ok iv put a tt gearbox manual with n/a flywheel clutch do I need a n/a starter motor or a tt one as I try to start the car and it sounds awful iv pulled the starter off and the teeth on the flywheel look as if I will damage them if I keep going, the starter will freeze and whine cheers ted
The starter motor teeth cannot reach the smaller n/a flywheel, as a work around you need to grind some of the starter face away where it meets the box to get it to mesh better, only a work around not a complete fix, fitting the correct box or a TT flywheel/ clutch assembly is the only way to do it reliably.
Jeff TT
cheers jeff I had a gut feeling someone was going to say something like that so I do the starter how much needs grinding m8
m8
m8
If you look at the starter there is a clear level where you can go no further due to shape/design, take it to the max unfortunately you will still probably get the occasional grinding...yuk!
Jeff TT
don't like the idea of that looks like gearbox out, pants and it came with a flywheel and clutch thought I was doing good putting new in well on my back again on my holiday the wife ant going to be happy
