gearbox
hi guys ok iv put a tt gearbox manual with n/a flywheel clutch do I need a n/a starter motor or a tt one as I try to start the car and it sounds awful iv pulled the starter off and the teeth on the flywheel look as if I will damage them if I keep going, the starter will freeze and whine cheers ted
The starter motor teeth cannot reach the smaller n/a flywheel, as a work around you need to grind some of the starter face away where it meets the box to get it to mesh better, only a work around not a complete fix, fitting the correct box or a TT flywheel/ clutch assembly is the only way to do it reliably.
ย
Jeff TT
cheers jeff I had a gut feeling someone was going to say something like that so I do the starter how much needs grinding m8
m8
m8
ย
If you look at the starter there is a clear level where you can go no further due to shape/design, take it to the max unfortunately you will still probably get the occasional grinding...yuk!
ย
Jeff TT
don't like the idea of that looks like gearbox out, pants and it came with a flywheel and clutch thought I was doing good putting new in well on my back again on my holiday the wife ant going to be happy
