Gearbox sensor
Hi Guys , at the rear of the gearboxes, i'm assuming its the same for all variants, is a cylindical casting at an angle. When removed there is a gear at the end which splices onto a wheel inside the rear of the box. now the one i removed from a NA auto box does not fit the hole of a TT Autobox, so there are some differences, but my main question is what does this sensor detect?. is it speed or rpm?
Also, if i reduce the dia of the sensor to fit the TT box, (its a couple of mm off dia) will it work?
Rich
Bear in mind that the TT and NA have a different diff ratio, i'd find a TT one tbh.
