throttle body mod
I know that you can remove the limit stop on the throttle body, buts whats wrong with removing the flap altogether
i and others spoke about this before ..
with the air flow is not direct entry to tb... but the butterfly disc .. sits more at 80* to the flow of the inlet pipe
if you was to mod the stop the butterfly disc will not be inline with the flow of air its quit hard to explain sorry
but dont move it
can you swap out the throttle body for a larger one ?like a tt one or are they the same diameter thus keeping the angle right
TT/NA are the same there are other mods that u can do fitting bigger butterfly's but that involves making the inner hole bigger .. u can easily stuff it up .. other than that
the Upgraded ones on Z1/CPZ ... direct bolt on but at the cost of $400+ post/dutys
ok mark thanks remember reading something about that!I have got a spare throttle body might have a play
