fuel filler flap??
Ok bit of a problem, the fuel filler flap wont open on the zed!!! Any ideas how to get it open???
I think that if you remove some of the plastic liners in the boot, you can access the cable so as to opperate the catch.
maybe the cable has stretched slightly?
Also, when you do get it open, check the hinge pin, it has a habbit of slipping out slightly and makes things stick.
Also, when you do get it open, check the hinge pin, it has a habbit of slipping out slightly and makes things stick. USUALLY THIS! You can just get to the pin with a thin flat blade and pop it back.
