Any sparks out there?
I'm in the process of sorting my kitchen out and have come round to the replacement cabling part of the job...
I have ordered a new kitchen with a ceramic hob and single elecic oven.
Originally it was all gas but that has been disconnected now... Basically I can't seem to find a proper answer as to what I actually need for the separate electric hob and oven.
Having consulted a couple of people it seems that a single 6mm2 cable will be suitable to supply both appliances. Is this correct? At this stage I'm just running cable under the floor and into back boxes.
At the moment the house has a nice 1950's fuse box which I will have replaced in the next few weeks. I just wanted to have all the new cable in ready for when that job is done.
Thanks chaps
how many watts is your oven running at as not all single ovens will be 2.5mm granted most nowadays are but always good to check
Hi
A lot of oven have 13amp plugs fitted which should be ok for you but check the load of both items that are going to be used .
If you are fitting a cooker switch with a socket on it,you will have to place the circuit on a rcd circuit breaker, not all hobs connect to 2.5mm some require bigger cables sizes if its gas then yes it will have a plug on it for the ignition and just plug it into a normal socket
Yes, but it will have a maximum wattage written clearly on it and any eletrican should be more than capable of working from that. ;)
watts + Amps x Volts 240v x 5 amps is 1200 watts
the higher the amps the thicker the cable needs to be
likewise to work out amps if you have only watts
watts / volts 1200 watts / 240 volts = 5 amps
generally for cookers you need a seperate fused isoation
for single oven depending on Ampage / wattage you may get away with a 13 amp fused plug
Spend the extra Chris and get an Induction hob not just ceramic ..the savings in electric usage alone will offset the extra initial outlay in less than a year
PM me you number mate , i dont have it in my phone ...if your mate is stil going to be kind enough to polish my vandal scratches out when i get back to UK
cheers
steve
use dont use 240v to calculate anymore its 230v :thumbup1:
iff you rip somebodys spelling on a post just make sure you dont fall over yourself:tongue::rofl:
Oven:
Energy
Current (A) - 10.4
Voltage (V) - 230
Frequency (Hz) - 50
So 10 Amps for the oven?
Hob
Energy
Connection Rating (W) - 5.8
Front right 1700W
Front left 1200W
Rear right 1200W
Rear left 2100W
Current (A) - 30
Voltage (V) - 230
Frequency (Hz) - 50
And 30 amps for that?
I've since been advised to run a seperate 2.5mm cable for the oven and a 6mm for the hob, which sounds sensible to me.
Steve, I'll PM you for numbers... for the amount I cook and the fact that id have to buy new pans (I think?) the cost of the induction hob wouldn't really be worth it plus i never realised they were cheaper to run and its already ordered and on its way haha.
