Fuel pump advice
Hey guys and girls when i start and run my zed there is a loudish humming noise comming from the rear of the car, now im thinking fuel pump is going bye bye but i just wanna be sure, Also were the heck can i find a new pump ive check japspeed zcentre etc and none have any listed. Im going to do some work on her this weekend so what ill do is take some pics as an update and film the noise for a better diagnostic
Hi Mark, Jefftt will supply you with a good used fuel pump and I think you get some warranty with it.
Paul
well i need to figure out if thats the problem first but ill defo get onto jeff or dk if thats what i need
Anyone with any advice regarding the noise issue
iff its a humming then the pump seems to be working fine mate
Are you sure it's the Fuel pump? The ABS pump is in the boot and you may also have an Amp in there as well. Could be one of them humming.
also check under the passenger seat for a 12" rubber vibrating dildo...ive heard those Duracel batterys can last for months on low power setting.
iirc that only happens if you've had Dazvert in your zed?
ha ha i dont know ill film it this weekend and maybe you can tell what it is cause i dont have a clue
remember mate this is a family forum:D...on a serious note iff the car is running ok then it must be fine
yeah but the noise is loud and that cant be rite
tbh mate, the stock fuel pump is a pretty reliable beast and if it is on it's last legs you'll be able to pick one up from here pretty cheaply. Once you get your vid up we'll have a better idea of what's going on.
  • 1 month later...
Resurrect time .
I have a similar problem , noticed it this morning.
Start car up and for first 30 seconds, there is the buzzing from the pump.
After a while it goes away, then if I press the gas even slightly, it starts again until I let the gas go.
How much is jeff charging for his replacement items ?
Ed
