brakes
okay I now have my car MOT'd and running sweetish...I am not overly happy with the brakes, they heat up big time real quick if driven hard...I want to try the 350 cars rotors, does anyone know who makes the adaptor bracket for the calipers...am assuming the bigger rotors should enable me to run harder longer with better braking and less heat fdade...i have 19 inch wheels so space not a problem...
silverline is looking at producing them, they do make a bit of difference but they arnt a substitute too better brakes, the benefits are mostly cosmetic in most peoples opinion. a set of claipers from a r33 with the 350 discs would be far better.
For a cheaper option yes the 350Z or GTR discs and brackets is a start, if you cann afford the relevant calipers though all the better, however the discs on a 350z are different offsett size to GTR, so if you buy 350Z calipers you fit 350Z discs, if you fit GTR Brembo calipers you fit GTR discs, both same size in diameter and thickness, but not 100% the same.
smithy
who is selling? okay let me get this right the 350z rotors wil fit but I need an adaptor plate to fit my calipers...does anyone know who can make this adaptro plate..a biiger rotor will improve the braking force for sure..but agree that bigger brakes more than likely better, but I just am not going to spend 2 grand on brakes for a 3 grand car...would be silly
