Hicas
To check your HICAS (just incase you feel the urge) this is the procedure, not sure if it works i
havn't tried it yet.
Procedure:
1.Ignition switch 'off' manual tranny in neutral or a/t in 'p'
2.start the engine
3.within 10 seconds after turning the key to 'on', start the engine, turn steering wheel from left to right 20 degrees from neutral 5 times or more & pump the brakes 5 times. then press the brake pedal again to enter test mode.
4.turning the steering wheel left or right past 20 degrees will cause the rear wheels to turn (~1 degree)
5.Drive the car forward 15 feet under 9mph to enter the full diagnostic mode.
6. The HICAS dash light will flash a code indicating any problems. long flash is first digit, short flash is second digit.
7.Diagnostic mode is exited when: ignition is turned off, or if speeds exceed 9mph, or diagnostic has been operating longer than 5minutes.
HICAS LIGHT CODES FOR '90-93'
1.HICAS solenoid R.H
2.HICAS solenoid L.H
3.Cut-off valve
4.Power steering solenoid
5.Vehicle speed sensor
6.Steering angle sensor
7.Steering neutral position sensor
8.M/T: clutch sensor A/T: parking brake sensor
9.M/T: Neutral sensor A/T: Inhibitor sensor
:cool:
No posts to show
