F1 racing flywheel lightweight - nssan 300zx twin turbo
Only ever heard bad things about these. From slipping with only mild power increases , to the friction surfaces coming off and the thing falling apart.
I got the F1 racing light weight flywheel and stage 2 clutch (rated at 409 hp) and looks like a quality product, the motor response has improved and so far the clutch is holding out well. The motor is rebuilt with port matched and flowed heads to inlet/exhaust manifolds and boosting 1.1bar and so far no signs of slippage however I am not one for revving and dropping the clutch at the lights. I will see if it holds out when I fit the kit to my forged motor with gt28rs turbos in the next few months. There are a few on the ozzy forum using this kit and have good reviews, I based my purchase on them.
In a nut shell I am happy.
Considering the cost to replace the fly wheel if it does not work, I’m thinking that it's probably best to stick with my original plan, a Z1 Motorsport flywheel. I guess at least you know that you’re not going to have any problems....
Was the Oz clutch Stage 1 or Stage 4?
Pretty much what I had read and concluded as I have a stage 3 similar XTD ebay clutch/flywheel from the USA.
No slipping for me either and I have run 20 psi, I am also happy :cool3:.
Bad reviews often stem from poor fitment :mad2:.
I`ve got that with an exedy clutch and it`s been fine.
