AVC-R boost problem
Hello guys.
So i got a problem, my AVC-R, no matter what boost i set up, max boost its always 0.9 bar.
Yesterday i want to test something and i set it up for 1.0 bar, max boost an AVC-R screen was 0.9 bar.
So i try set it up at 1.1 bar , short run and.... 0.9 bar on AVC-R max boost screen...
I got GT2560R turbos so i think 1.0 bar is not a big problem for them...
Anybody know whats wrong?
PS. my AVC-R setup is like this - http://z32.wikispaces.com/file/view/TT_Vac_BoostController.png/231588342/TT_Vac_BoostController.png
Cheers Konrad
  • Replies 31
  • Views 765
I haven't got a clue mate sorry
Could it be an actuator issue rather than a problem with the EBC?
Yea, but i dont have idea whats wrong and why i cant boost more than 0.9 bar :/
Similar issue on here:
http://www.google.co.uk/url?sa=t&rct=j&q=avcr%20won't%20boost%20more%20than%200.9%20bar&source=web&cd=2&cad=rja&ved=0CD4QFjAB&url=http%3A%2F%2Fwww.lancerregister.com%2Fshowthread.php%3Ft%3D118777&ei=incsUaqkO6Wm0QXnsID4DQ&usg=AFQjCNEGSoMzmHFFnlXlIV_1zRgjdCST7g&bvm=bv.42965579,d.d2k
Post #10 is what I was trying to get at
Say there is a new Forge actuator fitted depending on spring but with the ACVR off this sohould boost more than 1 bar ?, is he arm length set correct on the actuator ?.
The boost spike the AVCR makes before drop off is this what you have set in ie: through start duty or something the unit is over boosting on it's own ?, as this might be a control unit issue and not the solenoid at fault.
Thx for a link :) .
I think i make two tests:
1) turn off AVC-R and see what bost my car makes
2) unplug Wastegates and see i can reach more than 0.9 bar (slow speeding up on 2nd gear)
Hmm anyone using AVC-R can post what settings he use please?
i hate bar, but anyway 13psi isnt too bad.
Whats the complete set up you are running? do you have dump valves and are they set up correctly? could be leaking boost if they are opening too soon due to pressure build up.
Could also be the waist gates opening and not letting you build boost.
If u cant make no more boost, try unplug it has u say and see if it boost right up being careful.
I had a similar problem on my zed, tried everything, then 1 day I took my dump vaves off put recircs back on has pulled off boost went to about 21psi.
From what I could make out dumpvalves were leaking inside and wouldnt let it make no more boost.
Have u got dump valves..
Snap ian lol..
Snap ian lol..
lol great minds and all that matey :D
U know lol.
Or were just thinking out loud whats broken so far on how cars..
U know lol.
My mods :
1) Turbos GT2560R
2) 750cc Injectors
3) Apexi AVC-R
4) Big FMIC
5) 2.25" free flow exhaust
6) AFR Innovate LC-1
Yep i got two HKS Blow Offs.
And some more les importand mods.
Edited by Draxan
My mods :
1) Turbos GT2560R
2) 750cc Injectors
3) Apexi AVC-R
4) Big FMIC
Edited by Draxan
I just bought gt2560r turbos too, what they like hope there good lol.
Take it u dont have dump valves.
other then dump valves, try pulling pipes off has u said leave actuator side open block the other side.
If it boost more then u know its to do with controller or something like that.
