door rubbers
Hey again does anyone know were i can find the door rubbers or whatever there called that go around the top of the windows and round seems mine are leaking, Was washing the car for the first time the other day and realised there was slight drips of water on the passenger side seat
Are you absolutely sure it is the rubbers that have gone? i.e split/shrunk as it`s usually the targas causing the leak. A few people myself included have been having issues with water ingress lately. See if you can see any rust under the lip of the targa top. This is a pretty good indicator that the seals and inner seals of the targas are past their best , with the only option to rebuild or replace. The other likely spot is where the A pillar seal you mentioned joins at the corners, usually needs resealing with rtv or, as i`ve found to be even better sikalastomer 710 buytl sealant. Good luck.
I have all door rubbers and trim available if you are not able to fix the problem. Good luck though.
