Standard battery earthing points
I've just removed my age-old grounding kit and gone back to a stock negative terminal clamp. Does the standard setup have any additional earthing that I need to obtain and reconnect?
ok let me rephrase that - as standard does the Z have an extra lead that connects from negative to the chassis/engine block for extra grounding? will I risk causing any damage if I run the car without any extra grounding? :)
Bolts to the chassis half way across batt on bulk head ... then a small tie clamp .. down to the Head and bolts there then on to the Top bolt of the gear box
