auto to manual wireing
hi iv looked at the auto to manual wireing conversion on midlifz and gold and it don't show up only part part ie 1-4 the rest is blank any one got a manual to show how to do the wireing from auto to manual cheers ted
Just retain the auto loom, link out the starter inhibitor circuit and add reverse light cable from gearbox switch to the original plug on the inner wing behind the o/s headlight, neutral switch is optional, but if you decide to fit it, then cable over the gearbox and run into the cabin on the passenger side and you can connect to pin 44 on the ecu easiy.
Jeff TT
hi jeff but reading some emails there a plug in the wing that has to be looped to start the car with the clutch in with this pin 44 do I cut it or just join it I think im getting the man loom as its everything to do the conversion I just want everything right in my head and on paper before I start on it ted
I just cut the starter relay out completely and linked out the two relevant cables, there's plenty of threads on it and articles showing pictures of the bits you need to cut. its actually quite simple. :)
hi yea iv looked at some threads on here but thay show upto the gearbox plugs then on the rest of the photos its just x out I think I keep looking I want to get it right and not cock it up
