little bubble
My z has developed a small ( 1/4" dia) paint bubble on the rear drivers arch,( mid position on the curve) there is no rot , and the car is solid, so can anybody advise a suitable company and guestimated cost to sort the blemish out . thankyou
sayers
how can you be so sure theres no rot? if its bubbled, its bubbled for a reason. has the paint lifted and bilstered or is it surface rust?
Agreed, I recently addressed a light bubble, turned out be a lot worse than I imagined once I started delving.
It was a nightmare!
you can bet whatever is behind that bubble will need chopping out! i had a bubble the size of a 1p on my rear arch. you dont wanna see how much they cut/ground out!
Wheel arch corrossion can be likened to one of these.
Short repairs can can be done ( chips away style ) but unless all of the problem is cut out then it will come back sooner than you think, no short cuts unfortunately, having had our tame welder / painter repaired scores of them it is often much worse than it looks, the sooner you deal with it the less costly it will be.
Jeff TT
so Jeff, would you be able to look at this for me , or point me in the direction of a suitable company please ??
