Greddy profec 2
Hello maybe somone can tell me what is wrong with ebc. Just bough ebc profec 2 and i took to garage,and connect wire to battery but the unit just bip and flash red on scrren it is foulty?
help enyone please cheers Pit.
Is it all wired up properly? All sensors and solenoids piped in aswel. I got a red light when the boost sensor failed. And think you can set a warning for maximum boost and it goes red when the boost goes over it.
So if you've just wired the unit up with power and no sensors or anything else it might be warning you that it's not getting readings.
Hope this makes sense.
Danny
sensor is connected to unit all is connect proper but when i connect to battery unit start flashing and biping ;( can do anything
Can you use the controller? Just try a few settings in the menu. What does the boost read when you start the engine? hopefully someone will come along and solve this for you as i have limited knowledge but seems like maybe its getting a false reading from somewere which is makes it beep and flash to warn you.
thanks
danny
The fact that it is beeping and flashing suggests to me that it's working as this is what they do.
Seems to me that your just unfamiliar with it, took me a while to get used to mine.
read instructions manual again or your garage doesn`t know what they are doing
