protoj · 4 hours ago 4 hr
Thanks for your help guys,Jeff tt and all the Rac came out i had intention of getting her towed to garage but the guy has started her said is was flooded and had probably got a bit of condensation in as a result of heavy rain but she fired up he revved her hard and loud burnt all excess off and she is running fine at moment.
so thanks all
Simon
