Interior light problem
Interior light problem on Artztogo 300zx
thought it was Door Switches .. but been changed and still the same
Symptoms is all works fine lights on off with door open/shut .. but leave it for 10>20mins and the lights come on by them self ?
can any one shed any light on to this .. lol
  • Replies 36
  • Views 885
lol u know i went to change that .. and i couldn't see it what so ever ... its normally attached to the reinforcing bar it looked like it doesn't have one
but if the relay was faulty it would be on all the time of just off ...
its not a switch ... and not that the boot switch only does the boot light thats not coming on its the main one in the car that is
The boot when open also lights the cabin, the catch is the switch and sometimes the 3 screws need tightening or re adjusting.
enlighten ?
far as I'm aware there isn't an alarm just mobilizer
and if they was sure it wouldn't be wired up to the light wiring
but this would bring on the boot lights ... if it was that switch ..
just the cabin line is coming on
i take it there is no other control box .. mini ecu for the lights then like on other cars
just simple power relay/switch>lights
im pretty sure the timer control unit has an input on the inerior lights . maybe moisture in there as its near the targa pipe by the loud pedal
you wont see Chris's boot light with the install surely?
Yes as its wired to his Sub/amp lights so when its on the hole boot lights up like black Pool illuminations
he has been getting alot of water in car due to crap tagra seals that was supposed to be good
Brill so there is an Mini ECU is that the semi clear box behind the side foot panel right of the fuse box ?
Yes TCU in the footwell next to the fuel pump relay. In some models the TCU is responsible for interior light dimming/delay, so its possible a track burnt on the board could be causing the issue.
enlighten ?
the reason why i said it was my old alarm had a courtesy light feed wire to turn the light on when you opened the car with the fob
the only thing there on his car was just the fuel pump Control box ...
there was no other box or replay
ok .. well if its alarm playing up .. but its still working as it should then needs alarm techy
its a little white box about the size a a fag packet . it might be tucked away behind the fusebox
oops too slow
Edited by andyzx
text
yeah that should be next to fuse box ..drivers side foot well ..
your post above b4 said it was next to the fuel pump control unit :)
Doh! ... fook it ...
Oh will check that for him
Thanks for clearing that up :)
Edited by MarkDerby
  • 5 months later...
we replaced all relays and control unit but the problem still remained .. however we did find the problem in the end ..
at the time fitting all chris lights all was working unill this problem
found out later that he tuck the Normal Bulb out of the center light
as it wasn't "blue" well i kinda wasn't told this
well it turns out that the control unit needs to sense some small Load
from the internal lights ..
as all lights have been changed to LED bar that one
so just to recap .. use normal bulbs or LED that are load/volt type
you know the white box. if that is dud will it still work the boot light??
