Rebuild Parts
So im writing a list of bits i need/got to complete my rebuild heres the list can anyone think of any other bits i may need, list may change as i go along,
this is just for the rebuild already got loads of other parts like ebc,alloy rad,ect ect
Full gasket set
NA Oil Squirters
Full Bearing Set
Eagle Rods (got)
Wiseco Pistons(got)
Cosmetic Head Gaskets
ARP Head & Main Sud Kit
Garrett gt2560 Turbos(got)
Braided Turbo Oil Feeds & Restrictors (got)
Z1 bb Oil Drain Kit
6 Puk Clutch & Lightened Flywheel
New Crank Sproket
Full cambelt kit (got)
Oil Pump
Jecs 550 Injectors & Adaptor Kit (got)
Pcv Valves & Hoses
Z1 Viton Valve Stem Seals
if you can think of any other little bits i may need along the way add them to the list
Looks about right ..
I can sort u out with Light flywheel and 6puk clutch if your interested
all so the turbos u got listed there have you got the small actuators on them and the Boost in/Outlet adapters ?
turbos are z1 kit with adjustable actuators, what you mean by boost inlet and outlet adaptors?
also what 6puk and flywheel you got and whats the torque rating on it?
its the F1 6puk think its rated at 550lbft ... i havent had a problem with it .. but with my upgrade i picked up a excedy hyper twin plate
you should have a front mount plate for the inlet looks like a Oval alloy plate with off set holes ..
and some New 3 bolt pipes to mount to the outlet flange
Oh and forgot .. u will need to relocate your Stock oil sender on to the Filter housing unit
due to the braided line for the passenger side going direct to the block
how much you wanting for clutch, whats condtion like? any pics? also yep got the adaptors
i guess its straight forward moving the sender?
Condition is Good Loads of Life left when i checked last ( when engine was out ) Since then its done about 2k not off the car yet by the end of jan ..... Hows £150 ?
Same as this
http://www.ebay.co.uk/itm/F1-STAGE-4-CLUTCH-KIT-CHROMOLY-FLYWHEEL-1990-96-NISSAN-300ZX-TURBO-3-0L-V6-5spd-/200864533894?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec4758d86
