Which paint
Hey guys in just in the process of prepping the inside of my car ready for painting,
What type of paint and how much will I need to paint it, will be using spray gun
2K primer followed by 2K gloss. Std fast hardener should be OK provided you can get enough heat worked up in advance. There are "faster " accelerators too.
The BIG problem now is damp air and cold damp metal. A perfect recipe for micro blistering later:thumbdown:
As already discussed 2K products contain harmful isocyanates so you need a twin organic vapour charcoal mask as a minimum. Many would advocate a filtered fresh air supply.
As usual call to discuss further
