Well this is exciting !
Indeed - I can hardly contain myself. Stiff upper lip and all that hey?
Still - this means I can ask my Q again (snigger) and people will be sooo bored they might answer it!!
AHEM!
Whats the procedure for draining, flushing and refilling the radiator?
(gets off soap box, waves goodbye, puts coat on and goes home)
Will the last person to leave th forum please turn out the lights ....
Sorry Bilks me old mate - didn't see your last post anyway in the swaith of rubbish gags and off topic garbage (oooh handbags wink.gif )
Draing the Rad is as simple as ought ... Not
Simply Take of the pressure Cap, , Get the Car jacked up , Undo the Drain Pentcock which is a little rubber wing nut lookin thing on the Drivers most side of the underneath of the Radiator - Make sure you have something underneath to catch the fluid. Go and read War and Peace ... twice. then hopefully you will have drained most of the coolant. I Undo the bottom drain hose to get what is left out - it generally comes out in a fair size gush from there.
you may also want to undo the Overflow and drain that out too - look at the water line coming from underneath the filler top.
If you need to totally flush the system because of contamination (i.e all the water ways around the block Etc) you will be best of taking it to a Dealer as you will need to attempt to pressurize the system with a break in it to bleed the water off.
Refilling is just Do up the Drain cock and reconnect and pipes that have gone a stray.
Mix up the Coolant - Dont forget the anti freeze - its gonna be a cold winter smile.gif
Fill up thru the filla cap untill you can put no more in there( excess will drain into the overflow resevoir) then start the engine and let some pump thru the system - fill up more as you need - once finished check the overflow tank level and go for a little drive - Keep a VERY carefull eye on the Coolant Temp for the first few miles _ DO NOT let the car overheat - If it gets too hight then you haven't put enuff in - go back and put some more in thru the Filla cap.
Hope that helps
Z ya
Nico 91TT
Nick, you not talking to me then?
What's happened???
Tim
Cheers Nico - have bought Holts Rad flush in a DIY sort of fashion. So will do this Saturday morning.
Ahhh Timmy you know i love ya smile.gif.
Z ya
Nico91TT
p.s that Handbags remark was a direct jape at your all togheter humerous posting in the old dead forum....
Phhheewwww, thank God for that, thought you'd come back SO seriously techy that you were never gonna speak to me again!!! biggrin.gif
Huhhhh, don't say that mate!!! GULP!
You can revive it can't yer Nick, please say you can save it!!! Life will never be the same again without the "Old Dead Forum"
I take it that the forum collapsed under the weight of all that Z Bullshit then!!? biggrin.gif biggrin.gif
Banzai - if you need any help with your homework let me know - you obviously have the intelligence of a small rodent so you will need it biggrin.gif
CheerZ,
Andy
