DET SENSOR 34 advice needed plz
hi guys , ive done an ecu test on my car and when i first done the test it showed 34(det sensor)
now ive been expecting this as ive got a very slight detting sound(gurgle)
but on loads of testing the ecu ive never got any codes?
now tonight when i did the test it only showed 34 for 3 times then it went to 55
how can i sort this prob?
ive also got an a/f meter installed but its only wired into 1 side as ive never done a switch and dont no how to install 1
does anyone no of a tech page to install a switch for the a/f meter?
what could be causing the 34 det sensor(detting)?
i no its a lack of fuel or overheating spot
im gonna try a coolant flush AGAIN
what else can i do
im also running on super unleaded at the moment(not optimax)
Hello Jay,
If I remember rightly, code 34 means the sensor circuit is faulty. Check the connector is not full of crap as that's what happens on mine.
Vijay
just checked the det sensor connector and i have a dodgy wire going into it(loose)
thanks .jay
