well... what next?
so peeps.. what should the next stage be?
apexi intake... check
japspeed exhaust system.. check
japspeed decats.. check
2x Bailey DV26 BOVs.. check
HKS EVC 3.. check
ECU chipped and mapped to 1 bar.. check
nasty annoying rusty lumps removed and welded and sorted at the bodyshop... check
fuel pump a good next step? so far i've managed to bring all that together including the purchase of the car for £2.1k and am on a budget. suggestions?
Clutch and Flywheel
Alloy Pulleys
New Stock Pump or datawech Pump
Twin Filter set up
Intercoolers
underdrive pulley - got to do the belts at some point too anyway, and the pulleys gotta come off to fix a minor crank seal leak i do believe anyway.
intercooler upgrade makes sense. still got the stockers. think i'd rather uprate the twin setup rather than go FMIC. keep the flow to the rad then ;)
next stage sell the car
- rolandas.....be gone foul beast! made that mistake when i flogged the Rx7! not making it again!
step 1 - i went down the boost controller route. managed to pick up a used HKS EVC 3 for £85. cheaper option would be jets, but i'd rather have a toy to do it than jets, and it gives you more flex in the long run to fiddle with the boost.
step 2 - ecu is a pre-mapped stage 1 tuned chip on a socketed ecu and i got this sorted via a mate. The chips are cheap to buy, but the socketting and/or finding a socketed ecu is a pain, and you need to make sure you have had a few things spec'd up on the car like intakes/exhaust/decat/boost controller(or jets)
i'm still planning on having this ecu mapped/dyno'd but not straight away. want to uprate the intercooler setup before i do that, make the most of it as remapping is expensive.. and everytime you change something, in theory, you should do it again.
