protoj · Tuesday at 18:48 4 days
As per title, does anyone know the thickness of the shim needed to allow the starter gear to properly mesh with the flywheel ring gear? Research suggests there is a shim plate available but does anyone know where from? Alternatively, I have seen it suggested to use some washers as spacers - but how many / how thick?
Thanks!
