Is it possible to remove the motor with the auto box still fastened if the car is jacked on blocks high enough and is there any other way to put slings on with the plenum removed??
yes ... but u need the car about 12" high of the ground Front and Back
i normally put it on Raps on front and Axel stands at rear
need to disconnect the steering shaft and drop the sub frame by 1>2" loosen bolts but not all the way
u can strap it around the Engine mounts each side or put on the two plenum side supports and used them ..
i normally use the Plenum and loop it around the first 4 intakes
thanks Mark
oh and dont for get to drain the auto box other wise when u lift it out it will piss out all over the place :)
