Wheres a good place to purchase a set of plugs and oil filter, and what oil is everyone reccomending on the full change?
Im running 14.5psi off stock (boost controller) so i think thats the PFR6B-11B plug??
appreciate pointing in the right direction, opie appears expensive at the moment compared to others online.
Mike at MJP in the traders section for OEM parts ;)
I would still contact Opie to see if he can price match. He offers good reliable service and you know what you're getting :)
Vijay
It's been covered loads of times mate, have a search on "recommended oil".
Most of us use 10w40 for stock engines, either full or semi synthetic.
Yeah look for Conceptua tuning on ebay, they sorted me out with a very competitive price on plugs
I think Opie oil man has a 20% off everything sale at the moment as well
are you sure they are the right plugs?
the recommended is Platinum (PFR6B-11C) not Iridium.
Im sure they were platinum, they were what everyone was recommending, if he doesn't have them there's loads of other sellers that do them for the same sort of price
I use NGK iridium IX Heat range 7 Gap 0.7 Part number 2667 in everything best plug Ive ever come across and only £6 each on eBay we use heat range 7 up to 23psi only ever had to move to 8 after 25psi
At what psi do you uprate from standard to those?
I use them on standard engines as well be it a 300zx or a supra no difference on starting that i have ever come across and often eliminates intermittent misfires from a standard 1.1mm gap plug as well half the price of some plugs and they take some real abuse before they give up even down to plug wash from running severely rich on badly setup cars
