the right tools for the job, connector cleaning
for those wising to clean terminal connectors, we all struggle trying to find something to clean the pins with, mainly using a small precision flat head screw driver, sand paper and what ever else has a good contact to rub the crap off the connectors, sometimes with varying results and some times with out paying attention can inadvertently make the connection worse by making the gap wider between the pins to stop it getting a decent contact.
So if you want, here is the correct tool for the job.
http://www.ebay.co.uk/itm/Professional-Automotive-Electrical-Wire-Terminal-Connector-Cleaner-Restorer-USA-/280951350170?pt=Motors_Automotive_Tools&hash=item416a01639a
fantastic bits of kit and well worth the money
I got all exited until I saw the price...
but as you say not to bad considering how important the job is.. :)
just bought these:
http://www.ebay.co.uk/itm/10PC-NEEDLE-FILE-SET-HOBBY-140MM-VALVE-SET-MODELING-/251108799539?pt=UK_Hand_Tools_Equipment&hash=item3a77403433
until I can muster the courage to spend the money on ones you posted...
Edited by Medallion Man
anyone else got any good suggestions, think this was a damn good thread, also any other tips and tricks or tools for zed specific jobs
paper nail files from the £1 shop . they work a treat
OK, but how about stuff for the Zed.... :tongue_smilie:
good for the male side of the connector, its the female side thats the annoyance
No suprise there eh?
Jeff TT
i used contact cleaner/oil on mine didn't do a bad job just spray on and watch it bubble away as it removes the crap
  • 4 weeks later...
I used this stuff, it's mildly acidic and you can see it bubbling up on contact with the corrosion. Cheap too :)
http://www.toolstation.com/shop/Automotive/Lubricants+Sprays/Contact+Spray+400ml/d60/sd2795/p81507
A needle file will clean the female connectors.
That stuff is great i've got some, I also use a fibre glass pen that someone who services lifts on here recommended which is brilliant but wear gloves the fibres stick in your fingers
http://www.ebay.co.uk/itm/FIBREGLASS-CARBON-FIBRE-ABRASIVE-CIRCUIT-BOARD-CLEANING-PEN-PENCIL-10-REFILLS-/270971223928?pt=UK_Sound_Vision_TV_Boards_Parts&hash=item3f1724bf78
To finish off I use some marine grade contact gel that Boldy recommended but can't find the link
