protoj · 19 minutes ago 19 min
Hi guys, usual rear quarter rust issues. looked underneath the other day, and its coming through on the front edge of the rear quarter. Anyone sourced a repair/panel kit for this?
found these, but has anyone got any UK based sources?
http://www.jcwhitney.com/keyparts-quarter-panel/p3056930.jcwx?filterid=c15280d1663u0j1
