Need a 12V ignition switch controlled supply
Hi guys, as nobody bit on my post about a dual LC-1 install I'll take what info I can get ;)
I need a 12V (5A max) x 2 power supply to power up when the ignition is switched on to drive the heating elements in two LC-1 wideband sensors. Where would be the easiest to tap this from? Can be in the engine bay or (I guess) the loom behind the dash.
Any problems likely from connecting both sensors to the same supply?
TIA for an advice..
H
No posts to show
