Help with my Conzult please
Hi peps
Been trying to download my Conzult on my windows 7 lap top with out fail!
I have the v 2.4 but just cannot seem to get it going............When I uploaded the original disc onto my old lap top worked 1st time and added a desktop icon too, but nothing seems to work.
Do I need to install original disc then the v 2.4 or just the v 2.4???
Heeeeeelp
Dave
Mine worked fine when I installed it on my win7 64bit PC. Maybe just not installed correctly? I'd remove/uninstall and try again. Install the original and then the update.
I'm not using compatibility mode on it but it may be worth trying that as well.
Tried all that mate, still no go........... what's compatiblity mode?
Dave
If you right click over the conzult icon and select properties. One of the Tabs is compatibility. Put a tick in the winXP box and try again.
It's worth a try.
It's worth a try.
Looks like it may have worked, off to my mates to connect his z:biggrin:
Cheers Mucka:thumbup1:
Dave
Right still not working!!!! plug conn into car red light and green light on .....then green light goes out......connect to lap top ....click on conzult then run but not picking up engine ecu !!!!!!!!!!!!!!!!!!!!then comes up comm function failed win error code 6!!!!
Checked re checked all connections all seem fine!
HEEEEEEEELP
