NA vs TT ECU
Hi guys - I have a spare NA ecu that has a socketed EPROM, which i plan to fit a TT remap EPROM into.
I have checked the PCB part numbers inside and they seem to be identical between the NA and TT boards, so i am rationalising that the only difference between the NA and TT is the EPROM which i wil be changing anyway.
Is this correct or have i missed something?!
M
I think Jeff will be the man to answer this question, send him a PM.
Failing that try AndyP as he does chips too
Thanks Groover - appreciate the steer. If no-one pipes up, Ill get in touch with them.
Cheers!
M
I have a feeling, but I don't think I have ever conclusively proven this, but the NA ECU does not have the boost control circuitry. So you can run an NA on a TT ECU or you can run a TT on an NA ECU, as long as you have a separate boost controller. I know that is true, because it's what I do.
the ECU doesn't control the boost side of the car ... Only the Fail safe solenoids if theirs a Detected Problem with the sensors
so it should run with your tt e-rom chip but u will have no fail safe 7psi function
lol yep but looks like i missed your post as didnt see u posted the same thing
sooorrrryyyyyyy :)
