running fault
hi guys,
got a prob with the zed. under hard acceleration shes gone quite flat, doesnt pick up as well as it used to. also not as smooth.
under 1/2 throttle theres no noticable difference.
it doesnt miss at all, just flat. new plugs ptu, all connections cleaned, no faults in ecu. only mod is cone filter so far.
my initial thoughts are collapsed cats/exhaust - will check this when my new mongoose sys turns up. or AFM not giving correct readings.
anyone had similar probs??
I feel the need, the need for speed!
hmmm, just had a merc sl320 in with similar running symptoms as mine - 1 air mass sensor later & alls well.
anyone local to me (se kent) got one??
i think one of the andy's here breaks cars & lives in kent. U got any ???
I have a spare which should be winging it's way back from Macca very soon. In the meantime you could try cleaning the hotwire (very gently) on yours and/or resoldering any dodgy looking joints on the circuit board.
was gonna try that once i get a spare hr or so.
ill see how i get on with that
Have u checked for safety boost??
By that I do not mean the ecu check which is not too reliable on telling when the last det sensor fault was actually occuring, an intermittent fault here can lead to a clear code (55) It is worth inserting the 1 meg resister in the det sensor connector AS A TEST! Have seen this many times now ...worth a try.
Jeff TT
[This message has been edited by Jeff TT (edited 16-09-2002).]
boost gauge is reading what it always has, about 12 psi on the stock gauge.
ill try that tho. got a decade simulator at work so ill chuck that inline.
cheerz jeff
[This message has been edited by Paul C (edited 16-09-2002).]
