i've recently had an engine fitted and i'm now having electrical problems since the fitting, zedworld and zedcentre seem 2think the loom has being damaged in the process is there anyone in the middlesbrough area who knows what they are doin!!!. also having problems with abs, abs ecu indicates 9 lights (motor relay), i have changed relays on unit and also tested them and they are working fine so i then changed the unit and still getting nine lights on ecu, ive also tested the abs with a second abs ecu and that still states nine lights, any ideas??????.
