September 7, 200224 yr Any one got any pics? Manily reference what you did with the trim bits!!! Many thanks. Regardz
September 9, 200224 yr Hope aaron doesn't mind this http://www.mind-design.co.uk/nissanimg/boot_with_brace.jpg HTH CheerZ, Andy
September 16, 200224 yr You have to remove all of the trim from the boot - start with the panel covering the reverse lights. Then you have to remove the rear seat (four 10mm bolts for the back, velcro and pull upward for the base). Then the rear quarter panels - three or four nuts and clips. THEN you can remove the panels that cover the suspension turrets (jeez, hard work huh?) I used a jigsaw to cut the holes, but I'd recommend a holesaw - I can measure where to cut if you like. Fitting front & rear braces *really* tighened up the handling of my car.
Many thanks.
Regardz
