air ducts on a uk spec
can i convert a uk spec car with side lights an indicators into jap spec but no fogs just air ducts where the uk lights were
and can you buy the ducts to do it and the other sidelights that are diff to the uk ones
yep!
Fairly simple.
Fog light ducts from Car Mad on here... or Luke at Z centre.
J spec indicators available to buy on here S/h.
Some already have side lights in them
i might have a pair.
If you are running 99 spec front then you can drill and fit side lights in the indicators..... I have just done mine!!
yep!
Fairly simple.
cheers bud have 89spec bumper so does that make a diff
Easy peasey on an 89 spec. Just fit J spec indicators with sidelights already in them. I will look tomorrow and see if I still have a pair.
cheers budd let me know is it easy to alter the wiring or is it a straight swap
if you get jap spec indicators sidelights then iirc they are different wiring plugs. I have a UK spec and have adapted the black corner blanks to house both the sidelight and the indicator, by dremeling the same shape for the bulb holder to fit into and lock into place. Easy peasy just takes a bit of time. I think I had to extend a couple of wires too.
