what ID is the stock hose that goes TO the recirc valves?
as above^
I had them off today.. and I cant make my mind up if its 36mm or 38mm.. as i need to order a reducer for the dv26s I have on the way.
P.s. i didnt realise what a shit these things were to get off lol. Dear Nissan, thanks for using the worst clips you could find.
as above^
i cut through the clip, was so much easier, then get some T clamps for the new ones, job done.
exactly what I did in the end, got a pile of jubilee clips waiting to go on. nice and easy to get to the bolt on the back of the recirc valve eh?! removed the air con rad fan to do it in the end :) gonna get some 45º reducing elbows 38mm(or 36 :P :P) > 25mm and mount them that way :) depending if i find out what ID they are!!
Im not sure bud, mine already came with fitting kit and everything needed so never had to faff around with it.
i could have gone for the fk57 fitting kit which is £70ish on ebay. BUT, i've bought 2 used Bailey DV26 bovs, and including the 45º reducers i'll be all in for £80. i can live with that ;)
reckon it could even be 35mm without the swaged end... can anyone clear this up?!
sod it.. gone for 35mm OD aluminium straight connector, then 35mm>25mm silicone straight reducer for the BOV. All ordered, fingers crossed!
Are you talking about the pipe that the blanking plate goes into? If so it should be 32 mm had that problem with mine and just brought some new silicone hose from ebay
i've ordered the caps for where the recirc pipe used to go back into the inlet and have gone for 30mm which i thought might have even been slightly too big?? I'm trying to suss out the pipe leading to the valve (from below), not the pipe that did come away from it :)
the valves lower OD i'd say is 35mm>37mm with swaged edge so i've gone for 35 and rely on a little stretch if required ;)
