fuel pump fuse
I recently replaced my fuel pump but found it impossible (with my big hands) to remove the fuel pump fuse to drain the lines... Of course disconnecting the pump itself was fine to do this . However I need to replace the fuel filter now so any tips on removing tjay big square box fuse for the fuel pump. Or can anyone else me some japanese sized hands to perform the removal of the fuse :)
Are you trying to remove the correct fuse ? Small fuse box, next to the Brake Master cylidner. Small green fuse on the end closest to engine.
Pair of long nose pliers will do it I'd Imagine if cant get finger on the tab to squeeze.
If all you want to do is to release the fuel pressure to change the fuel filter leave the car overnight with the fuel cap undone, next morning no pressure! but be aware fuel will run out of the filter when undone.
Jeff TT
Just remove the plug on the fuel pump relay in the drivers footwell.
Fuel pump.relay sounds like a good idea thanks people ill tick that off as another job on the never ending list well done :)
