September 10, 200224 yr Anyone know the Nissan part No. for Jap spec front brake pads with the little bracket on that rubs on the disc when the pads get low. My main dealer insists on supplying pads without this bracket (4106037P91)
September 11, 200224 yr The part No is one digit different 41060-37P90 PAD KIT - DISC BRAKE F\RH & LH Other jap sepc Part No`s below 41l20-30P26 SEAL KIT - DISC BRAKE 41001-37P00 CALIPER ASSY - FRONT RH W/O PADS OR SHIMS 41003-03P25 GREASE - SHIM 41011-37P00 CALIPER ASSY - FRONT LH W/O PADS OR SHIMS 41217-30P00 PIN 41044-04U00 WASHER 41080-40P26 HARDWARE KIT FRONT BRAKES 41090-40P01 SPRING 41121-30P00 PISTON - CYLINDER (X 4 ) 41128-A0100 SCREW - BLEEDER
