Windscreen washer fuse
Does anyone have a clue which fuse is for the windscreen washers?? The wipers all work fine and the back one works fine, the rear washer also works, just not the front ones. Anyone???
Membership No 0780
INSURANCE GOOFA
ย
Im pretty sure Lee that if your rear washer is working, it is on the same circuit as the front. Both washer pumps are in the same bottle on a lwb, so i would try accessing them through the indicator lens and see if a wire is off or plug corroded. If you have enough room, try swapping the rear pump for the front and go from there.
ย
I dont think there is one fuse just for the front washers, HTH
Once you have checked out what Groover said,
It may be worth looking at the relay hidden behind the rear part of the front offside wheel arch liner.
Mine had similar problems and turned out to be a corroded brown relay.
Worth a look.
