Who can make me
Does any one work in metal fabrication or know where i can have these made?
The reason being is i bought some adjustable arms from a member here and the bolts in this picture are to short.
I only just found out the original kit comes with 2 types of lengths depending on car. But ive only been sent the short ones :angry:
Im cant find a supplier so looking in to other opsions
Thanks Dan
That is pretty simple to make. Any competent small engineering workshop could make them.
Can you measure them, as I may have a spare pair but not sure whether they are the long ones or short ones that ive got :)
Great ill pop down the unit tomorrow and measure them thanks Dan
Ok, will measure mine tomorrow and if they are any good to you i'll send them to you :)
I've measured them and taken a pic but I can't upload from my phone. It's about 120mm in length ill post the pic up asap. Thanks dan
Edited by GIBSTER-TT
Adding pic
Sorry mate, they are the same as the ones ive got, iirc the arms I bought came with two pairs,labelled S13 and S14, one of which I used.
so these are not Normal bolts for the pivot on arms ... but the adjusting turnbuckle between the rose joint and out arm mount ?
Yea that's right the bolt is tapered. It bolts though the rose joint of the lower arm and the other end goes though the hub. I'll post a pic as I can not do it off my phone but will when I get in.
Thanks Dan
the bolts i have are just normal ones of standard arms m8 ... dont think they will do the same job
