Boost controller rubber pipes
Is just I simple question.
What size in mm boost contoller pipes is the best.
I got blitz boost controller but i heard that if pipes is too long or to wide you will get more turbo lag
So how i can avoid that?
So i need to do two T joints so if i understan correctly
Two pipes from selenoid should be 4mm and the rest of them from T joints should be 6mm.
Or could i just put 5mm pipes everythere?
you will need
2x6mm Y hose connector
1x4mm T hose connector
1 meter of 4mm vac hose
5 meters of 5>6mm vac hose
