Removing cowling?
Well decided im going to freshen up the wiper arms and windscreen cowling, now having realised that there is almost no job i do on the zed that is easy i thought i better check how to remove the cowling? So is it like all other jobs on a zed or is it as easy as it should be?
It's fairly easy mate, been a little while since I did mine but basically it's wipers off then undo all the little plastic screws. You'll need to lift the bonnet for some and lower for others. The main problem you'll probably get is screws just turning but not coming out. Use a flat blade screwdriver to gently lift the screw while turning it and they'll come out. Halfords do plastic screws for the round ones but don't lose the rectangular ones as they are harder to replace.
Sounds easy enough then, although im sure the zed will try it's best to make it as hard as possible.
:lol: of course it will mate. Probably start with the wipers not wanting to come off. lol
